Hi all,
We're about to have some minor building work done (bricking up a window, replacing a door with a window). We're in a 1930s semi detached, and we suspect our mortar might contain lime. We've done a white vinegar test and I think it's fizzing enough to suggest it is lime.
However we've pointed this out to the builder, and they've commented that it's unlikely to be lime as our mortar joints are too wide for this. If we would like to use lime, they'd like to charge us extra.
So my questions - (1), does the mortar joint thickness mean anything re the presence of lime? (2) In a 1930s house with a cavity, North West England, is it likely to be lime mortar? (3) House has 70mm cavity filled with blown insulation, does it matter if they use lime or not for the changes?
Thanks in advance!
Russ
Thanks in advance!
Russ
