It's strange how experiences vary!
Yes I would buy a pack of 10 assorted bulbs from Tesco, pre the CFL I would change on average a bulb every other week, likely around 30 bulbs in the house.
The move to CFL was not good, these
did not look good in a chandelier designed for tungsten bulbs, and 11 watt was claimed as being same output at a 60 watt bulb, but light did not leave the bulb in the same direction, so fitted a new chandelier and used golf bulbs
and these took an age to warm up, but were claimed to last for years, so 16 between the two main rooms, with 4 new chandeliers, within the year, half had failed.
It was around this time, Lidi started to do LED light bulbs, I had bought a couple to try, seem to remember 1.8 watt each, idea was to use in table lamps, but since yet more of the Philips golf CFL had failed, used as a temporary measure in the main lights.
Next time Lidi had them on offer, now 3 watt, only had 8 on the shelf, so got 8 and so whole of living room was now lit with LED, likely this was around 2016, as they were not bright enough to read with, so swapped to 5 watt, and old ones went into mothers house with smaller room so they lit that room OK.
At this time I was making notes, and until my move to this house in 2019, very few LED's had failed.
On moving in, found CFL, tungsten, and even a pair of 150 watt quartz lamps outside, so slowly as lights failed they were replaced with LED, and also some smart LED bulbs, I started to find more LED failures, but not keeping records, and many changed to increase light output. Or to enhance control, rather than to replace failed ones.
By this year, I had assumed no tungsten left, to find the vestibule lamp still had a tungsten bulb was rather a surprise, well used lamp, and I have not fitted any tungsten so over 5 years old, clearly much better than CFL, I think still some CFL used outside, and maybe in the flat, but in the main LED now.
As to LED when daughter complains lights give her a head ache so changed, does that count as failed? Had a few develop a shimmer, but not sure if due to switch or lamp. So complete failure around 3 in 5 years, but not sure which lamps came from old house, where not bright enough, so second hand to start with.
