Change track rod and breaks before alignment?
7 Nov 2024
Vauxhall Astra CDTI ecotec, 1.6cc, 2017, 90'000 mileage mostly rural/town roads and some motorways.
I took my car to a garage for MOT and full Service. It passed MOT fine but had a few issues they wanted to repair immediately.
- Wheel alignment and front L tyre replacement (This definitely needs doing).
- All Break pads & discs ("visual check").
- Inner & outer track rod L side ("visual check").
After they tried to get me to agree to £1200 just on breaks £800 on a single track rod I got the feeling they were trying to rip me off and took the car back without work. I went to change the breaks myself but stopped when I measured 8-9mm on front breaks and 5-6mm on rear breaks, they still have half a cm of wear indicator on them. The L wheel has a small amount of play maybe ~5mm when pushing the tyre back and forth, I wouldn't say it feels loose, grabbing the track rod itself I can feel no play in it. The steering wheel doesn't shake or rattle while driving, and there's no noise while turning. It also seems a bit early to expect to change track rods at 90K miles. The only symptom is the front L wheel being out of alignment.
- I have also noticed a dull creaking noise (like stepping on old floor boards) when the car is misaligned height wise. If I were to drive straight over a speed bump there is no noise, but if I were to mount the curb or speed bump with only either one side of the car, it creaks while changing height. I gave the ball joints a quick spray because they've never been lubricated, but the creaking is still there afterwards.
If I need any work doing, I've got a month off work so now's the time to do it really.
So what I'm asking, ideas to find out the source of the creaking, and whether I should change the track rods on both sides (normally changed in pairs) and breaks, before taking it in for alignment, or leave it for another year and only do the alignment this week?
Sort out the cause of the play and then get the tyre replaced and the alignment checked and adjusted. You need someone to gently rock the steering wheel back and forth while you hold your hands on the joint to feel if it’s worn. Check that it’s not the inner joint where the play is. Spraying the joints will do nothing as nothing will get inside them.
I don't quite get this one.....you have a few MOT advisories it seems. (Advisories are just that - advisories).
Brake visual check........there seems to be plenty of material left on the pads, but what condition are the discs in? £1200 seems like I'm in the wrong job, likewise £800 for a track rod end?
The garage may have spotted uneven tyre wear, hence the recommendation for an alignment check.
For the creak, lubricate the anti roll bar bushes with washing up liquid - and any other rubber bushes that you can see. It could be a spring rotating in its top strut bearing as well, but that's unlikely. The bottom wishbone bushes get a hard time too.
5mm play? This could be a track rod end (or the track rod joint within the rack), a wheel bearing or bottom suspension joint. That's too much but you've just got the MOT?
I don't change both track rod ends (or springs) as a matter of course.
John :)
Track rod was a yellow advisory, alignment and breaks were a red advisory.
The discs are also thicker than minimum, there's some surface rust showing up on the non-contact edges but not flaking off or anything, I'm changing them next time I do the breaks anyway, but when I asked these guys to show me why the parts need doing urgently, they could only point out the worn tyre. The mechanic in that day couldn't tell me why the guy testing recommended new breaks when you can see the thickness without even taking off the wheel, and couldn't tell me anything was off with the track rod either.
I'm fine with advisories, but considering a few friends had similar experiences I get the feeling these guys might be less concerned with the car and more concerned with a paycheque. It's a Honda garage.
Thanks, I lubed the ball joints and wheelside rubbers but the roll bar is hard to reach so I'll take the two front wheels off, try to spray and chuck some grease in for good measure and report back on that front.
MOT was last week. play estimate was a guess from memory, I'll get a more accurate measurement from all the parts when I go out to the car later today.
If the creaking gets sorted by refreshing the rubbers, then whether the track rod needs changing or not will determine whether I change all the parts out before an alignment or not.
Sounds like a main stealer trying to drum up work with their own made up colour coded warning system to scare gullible customers.
For rubber bushes, no oil based grease please! Red rubber grease is fine, so is the white lanolin based stuff I believe.
You'll pay top whack at a Honda garage, but that's your business!
John :)
No such thing on an mot. It is either Pass, fail, or pass and advise. Alignment isn't tested, AT ALL.
Why are you changing them if there is no need?
Possible. but Unlikely
How did you lube the ball joints ?
What was the advisory for it ? Type it from your mot certificate.
Track rod ends needs replacing if worn, or rubbers split allowing grease out (which would be an mot fail) no need if not.
As others have said, those are pretty outrageous prices. If you really do have 5mm of movement at the wheel rim, then that's probably your tyre wear problem right there. Change the track rods and their ends, and then get the tracking done again. To be honest, I'm surprised that 5mm of movement at the rim wasn't an MOT fail? It's quite a lot. If your tracking was (say) 1mm out at the rim, you'd expect maybe some odd tyre wear, so if it's randomly flapping about 2.5mm each way, you're pretty much guaranteed odd tyre wear.
As others have said, the creaking is more likely to be a rubber bush than a joint. See if you can lie on the ground with a hand on each of the rubber joints in turn, while someone gets in and out of the car, and maybe you'll feel the creaky one (or hear it a bit closer)?
