- Joined
- 12 Nov 2024
- Messages
- 2
- Reaction score
- 0
- Country
I bought a brand new Secure/Horstmann HRT4 ASR-ZW thermostat with boiler switch. Manual: https://www.robbshop.nl/media/45/da/33/1670501179/SEC_SRT322_download_1.pdf
Reason that I bought it was I wanted to control the heating through Home Assistant, and this was the only Z-Wave one I could find for the price of 70 euros, but maybe I'm wrong, it does seem to be very old (it's not too late to return it)
I'm trying to connect it to the Vaillant ThermoCOMPACT VCW 255/4 E VR Combiketel 12,8 - 24,4 kW CW3 closed Manual: https://www.vaillant.nl/pdf-neu/thermocompact-vcw-255-4-en-cwk-245-4-144564.pdf
First thing that goes wrong is that there are no 230V L/N connections on the boiler panel. No RT connections either. Only 24VDC room thermostat connections at the numbers 7, 8 and 9, and 24VAC room thermostat connections at 3' and 4'. There is an 230V X12 at the bottom for "an added module" but it would require soldering.:
Thermostat connections:
I did my best attempt at wiring it, however, in the way it makes most sense. I wonder if it's just not compatible at all.
Here is my attempts:
Boiler unit, left to right.
REDWIRE1 connected to 4'
BLUEWIRE1 connected to 3'
BLUEWIRE2 connected to 7(24V)
REDWIRE2 connected to 8(24V)
Thermostat unit, left to right.
REDWIRE2 connected to N,
BLUEWIRE2 connected to L,
BLUEWIRE3 bridged between 2 and 3
BLUEWIRE1 connected to 2
I hope you guys can give me some guidance, I would very much appreciate it!
