Hi all
I have recently boarded out a room (with lots of help of these forums), and Im about ready to start plasterboarding it.
Ive never boarded out before, so this is going to be a learning curve for me. Im a few dozen videos into that learning! Last thing I want to do is make life harder for the plaster, and I just had a couple of questions of things I dont understand. Any advice would be appreciated.
I understand that tapered edges are better when butted together, to create a good join. What do you use going into corners, either internal or extermal corners. Do you buy seperate sheets of square edge plasterboard for these edges, or would you cut the edge off the tapered edge sheets?
Im doing it on my own, and as above Ive not done it before. I know you can get huge 2.4m sheets, but for one man I think these would be tough to handle...however, Im concerned that if I get the smaller sheets, the top/bottom edges arent tapered, so I would imagine this makes life harder for the plaster. What size do people normally order when doing the install solo?
Im planning to use screws. Should I coutersink, or just screw them in gong a little deper than the surface, and then cover them with filler? If covering with filler, does each screw need priming...or are plasterboard screws pre-primed?
Thanks guys...open to any other tips which might be useful for a complete noob!
