Hi All.
I would like to attach a flat sheet onto the top of an IKEA carcass (laminated MDF??). The carcass consists of a top and bottom with two side panels which are 18mm thick. The side panels are attached to the side edges of the top and bottom thus the width of the entire carcass equals the width of the top/bottom PLUS 36mm (18+18).
I would like to screw the flat sheet onto the top of the carcass using 6mm screws, so I have two options for the location of the screws. One would be to screw into the side panels and the other would be to screw into the top panel. I would ideally like to be able to screw into the side panels, to get as close to the edge as possible, but would this be recommended bearing in mind that the screws are 6mm and the side panels are only 18mm thick?
How can I drill perfectly straight so as to avoid the screws coming out at the sides and how do I avoid splitting the thin strip of laminate which covers the edge of the board?
Any advice would be very appreciated!
Thanks.
Thanks.
