- Joined
- 27 Jan 2008
- Messages
- 28,313
- Reaction score
- 3,441
- Location
- Country
Physics being physics, I presume that there must be at least some heat generated within the panels (sort of similar to what bernard has suggested) - does that not help to melt the snow?It seems PV1 is the bottom panel, and PV2 the top, and there is nothing I can really do to clean the snow off the panels, simply need to wait for it to melt. However there must be 1000's of solar panels out of action due to the snow, how does this affect the national grid?
That is, as you say the problem, there is someone watching the dials trying to decide if a gas powered station needs to go online.It is, however, an illustration of some of the limitations of 'renewable' energy sources - just like wind turbines don't work when there is no wind. Tides/waves are essentially unstoppable, so maybe they are the most 'reliable'?
... and that will always be the case if we become significantly dependent on solar and wind (although we'd be unlucky if nature contrived that both solar and wind failed simultaneously) - unless/until we have enough nuclear capacity, although I don't think that's necessarily very 'controllable.That is, as you say the problem, there is someone watching the dials trying to decide if a gas powered station needs to go online.
I used to live in a country that had massive underground storage for natural gas as a buffer against peak winter demand.... and that will always be the case if we become significantly dependent on solar and wind (although we'd be unlucky if nature contrived that both solar and wind failed simultaneously) - unless/until we have enough nuclear capacity, although I don't think that's necessarily very 'controllable.
The glass is black, so warms up reasonably well if there is some sunlight. Snow is not light proof.View attachment 363377 It seems PV1 is the bottom panel, and PV2 the top, and there is nothing I can really do to clean the snow off the panels, simply need to wait for it to melt. However there must be 1000's of solar panels out of action due to the snow, how does this affect the national grid?
Why are you not paid for export?It is slowly going up View attachment 363392but we have a clear blue sky at the moment with not a cloud in sight, without the snow would be looking at nearly 5 kW. I expect any time soon to hear another fall of snow off the roof and the output will jump up. However, not paid for export, and now at 75% charged, so likely will end the daylight with a fully charged battery.
I am with British Gas, who sent me forms, which I filled in, but they said wrong formate even when it was their form, there is a £75 exit fee, so waiting until April, and if not sorted by then will leave for someone whole will pay me, likely Octopus, but since winter not worth losing the £75 to change before the contract ends.Why are you not paid for export?
If you had swapped (to Octopus or whoever) when this problem first arose, would you have got less than £75 in payments for export in the period from then up to next April?I am with British Gas, who sent me forms, which I filled in, but they said wrong formate even when it was their form, there is a £75 exit fee, so waiting until April, and if not sorted by then will leave for someone whole will pay me, likely Octopus, but since winter not worth losing the £75 to change before the contract ends.
It doesn't.how does this affect the national grid?
366 in some yearsIt doesn't. The same lack of solar occurs 365 nights a year.
If you are going to switch to octopus start the export now. You will only get 4p/kWh until you import with them but it will make the export payments easy to get once you join.I am with British Gas, who sent me forms, which I filled in, but they said wrong formate even when it was their form, there is a £75 exit fee, so waiting until April, and if not sorted by then will leave for someone whole will pay me, likely Octopus, but since winter not worth losing the £75 to change before the contract ends.
