- Joined
- 21 Nov 2024
- Messages
- 52
- Reaction score
- 1
- Country
Is a Henry hoover, used with "HEPAFLO" bags, sufficient for containing the fine dust created from sanding plaster? Specifically, I will be smoothing out some recently plastered-in chases in walls (after a full rewire of my house, so quite a few chases)
There are plenty of threads and info websites which say a Henry or similar is ideal for this sort of thing - and plenty of others that say you need at least an L class vacuum. Obviously L/M/H class vacuums get a lot costlier...
What I'm not clear on is if using a non L/M/H class vacuum, but with bags, will still result in fine plaster dust being thrown out of the vacuum's exhaust - i.e. do the bags prevent this from happening??
And if a Henry is fine, what about the £40 wet-and-dry one from Wickes - is that just as good, or is worth shelling out a bit more for a Henry? Or something else?
Essentially, what's the best non-expensive vacuum I can buy that will contain plaster dust as opposed to just blowing it all around the house?
