Is this damp or discoloured bricks
20 Nov 2024
We are in the process of buying a house and we have noticed what looks like a damp patch on its external wall. Our vendors say that it’s not damp but different colour bricks that were not mixed by the bricklayer. Should we organise a damp survey?
Can't see a damp patch. Can you circle the area you're referring to?
I assume you don't mean the multiple black splodges which look to me to be something like....
I’ve circled it
Now I’ve got a photo of the front of that wall. Damp patch or bricks not mixed? Can the outside bricks be tested for dampness? I suspect all outside wall will be damp to some degree?
I would vote for damp, from that last photo.. Certainly worth a closer inspection, but it seems centred on that tap. I wonder if the tap, might be leaking? .
But is the inside damp? Really this is why you have cavity's, to separate the inner and outer skins so even if the outer skin is damp it should not effect the inside. I can't see the tap being responsible, if it even is a damp issue(?), some of it is higher than the tap, would have to be a pretty major leak to cause that.
true that but eventually with enough water it will start to be a problem on the inside too if its too much
Hmm, in theory perhaps but anyway a dripping tap, £50 for a plumber, hardly a house deal breaker.
Back to the OP, damp surveys are typically carried out by people who want you to use their damp mitigation/fix services and are one of those trades that should be employed very carefully.
