kWh, not kW (we've been here before)!-
Who cares
3, generally at home all day. Too many kW being usedHow many people live in this house?
I have been taking readings, generally first thing in the morning and sometimes throughout the day. Lived here for 4 weeks, 3 of which the UFH didn't work. Waiting to get a smart meter fitted at which point I can shift everything onto an overnight EV tariff, however, been waiting nearly 2 weeks for Scottish Power to change my MPAN number to be able to qualify for the smart meter... don't ask about that one!You need to take readings regularly throughout the day. By doing this you’ll see when the usage is high and when it’s cold the usage will be very high
How long have you lived in the property
Underfloor electric heating is a very expensive way to heat a house
70-90
Yes..... Our previous house was a 4 storey detached Victorian villa, insulated as best you can with that type of house and we were using 12-18kWh per day loadshifting overnight to take advantage of EV tariff, our bills were c.£120 per month. I reckon we're approaching 10x that as Scottish Power won't put us on any other type of tariff other than full rate. Locked in at the moment and not very happy about it.So with just normal living and an immersion you were using 70 to 90 per day
Ouch. I would say about 20 - 25 would be normal
That changes all I have said,70-90
my maximum usage (not drawn from grid but used) is 452.4 kWh for the month, so 14.6 kWh per day,Even that's a bit high, we use tumble drier, washing machine, dishwasher.Ouch. I would say about 20 - 25 would be normal
Yes, I remember one house where a socket had been connected to neighbour's supply, BBC news shows this guy so yes it does happen. I would be very worried with that load.EV, hot tub? Neighbour connected to you?
Then if I were you I would get some emergency form of heat for when the power gets turned off - black outs are on the way.Waiting to get a smart meter fitted at which point I can shift everything onto an overnight EV tariff,
There's no gas here so electric is the only way forward.
Looks like we'll need an extra jumperThen if I were you I would get some emergency form of heat for when the power gets turned off - black outs are on the way.
Looks like we'll need an extra jumper![]()
