My combi boiler works fine when running, however when it's left off for a while such as overnight, it loses all water pressure.
- I've checked and replaced the PRV and confirm that no water is lost at the PRV
- I've installed a new Expansion Vessel and confirmed this is working ok
- I've replaced the air valve
- I've isolated the CH flow and return valves overnight and the boiler still loses pressure - this indicates any leak is in the boiler but there is no evidence of water anywhere in the boiler, including the main heat exchanger
- There is no visible signs of any pipe leaks and all radiators and hot water works fine.
Water pressure is being lost somewhere but I cannot seem to fathom just where and yet the boiler is fine when in use.
Given that pressure is lost even when isolating the CH flow & return, my assumption is that one or both of these valves must not be closing fully and hence letting pressure out through the CH pipework.
Any ideas or suggestions for things I may have missed are appreciated.
