Attaching rafters to timber
15 Jul 2022
I have a patio structure done and now I want to attach the rafters.
The timber is about 4.7cm wide.
How long screws should I use to attach the rafters?
The rafter (birds mouth bit) is about 8.5cm thick.
The underlying timber is twice as thick so I think 16cm long screw would be enough.
Should I use 18cm long screws that are of 6mm diameter?
What drill size should I use for pre-drilling 5mm?
Or should I use brackets?
Are these soft brackets strong enough or should I get some sturdy ones?
On top I put EZ Glaze 3mn thick transparent polycarbonate.
The whole structure is rather strong 6x6 posts etc but of course I don't want the rafters to be lifted by wind one day.
We skew screw using 100mm 5's and then add truss clips (for uplift prevention) if needed.
Do you think I should bother installing those white wall flashings or just use 10cm butyl tape?
In my case the roof slope is quite decent.
Use the flashings. Tape will be useless after four seasons.
