Is this a light sensor switch? (Ed.)
29 Jan 2022
What is this please. On the side of my garage
You will need to follow the cable to see where it goes. You don't know yet if there is a fault, or what or where it is.
It goes to a light at the front.
Bulb is fine.
Light not working
I dont recognise that particular type. Open up the front and can tell you how to bypass it, then you'll know if it is that or something else.
OK. Lets have a look at the connection wiring inside the photocell. You may not need to buy any test gear (although, every home should have something). May be worth turning the power off, you never know what might be in there!
