Just had an oil to gas conversion done.
The company who carried out the work notched my 100mm loft joists pretty badly in this location of my loft, as you can see in the photo.
I have raised this with them and they are getting in touch with a joiner in order to put all this right.
Question - what sort of methods / techniques should be used here to repair or re-inforce these notches?
The pipes will need raised in order to run above the joists. Yes?
Down the line I want to replace all the loft insulation and achieve 300mm depth or equivalent - should I factor this into the equation when instructing work?
Thanks in advance
Thanks in advance
