What type of wall bracket for this curtain track?
27 Dec 2006
London
I've got this metal curtain track but no wall brackets for it.... It's 22mm high, but is smooth backed, so the bracket pictured will not work....
Any ideas anyone? Thanks!
Are you sure the smooth back isn’t the front? The rebate in the photo looks to be the mounting slot .
Thanks. Maybe... It would need to go into the rebate, and somehow secure there.... Rebate is 10mm wide....
It absolutely is.
And that bracket in the photo looks like the right one - the lever rotates a cam which locks it in place in the slot.
It absolutely is.
No it isn’t , I provided a link to correct bracket which was confirmed as correct .
I'm not saying the one you linked to doesn't fit, just that the one in the OPs photo looks like the right one.
Or also works, if it matters to you so much.
No it does not fit, it’s for completely different track .Totally different profiles.
Put track up yesterday with the new brackets. The slot definitely the wrong size for the rotating cam type.....
