- Joined
- 7 Sep 2022
- Messages
- 4,931
- Reaction score
- 1,437
- Country
Eh? You're each talking about the same thing
The thread morphed into the positioning of insulation somehow. Arguments over thermal mass gains, v's (internal) surface insulation will always rumble on, as the noticeable differences are minimal.Eh? You're each talking about the same thing
But you'd be advised to devise a robust detail to insulate them from the ground in that case
Thermal mass gains are fine if the building is occupied 24/7 or if temperature consistency is your thing. Busy family homes with plenty of windows and doors - pointless gains.
There is a reason architects, house builders etc chose the cavity over any other methods.![]()
You still have the benefit of thermal mass with cavity insulation, whereby there are gains from the inner leaf etc, but without the ball ache of thick insulation on the surface of the walls.Absolutely, Kingspan GreenGuard is good for this. But isn't it quite common for cavity construction to fill the cavity below a certain level, thus creating a cold bridge?
We have a busy family home, and with complete external insulation and modern well fitted windows, the house is a consistent 21 degrees all day (Dipping at night when the heating is off), and costs not very much.
Our original bungalow was of 1950s solid construction which we externally insulated, so when we extended we kept to the same method. It meant the footings could be a fair bit narrower, was easier to self build, and in the case of the heating failing the house remains warm for a day or 2.
Lots of Europe build this way now, cavity seems to be a quite British thing, and lets be honest, we aren't renowned for our utilisation of building technology.
Marmox blocks FTWto fill the cavity below a certain level, thus creating a cold bridge?
"Always" might be a bit extreme.. There are certainly alternative build implementations in existence in the UKLet's be honest, there is a reason why cavity insulation is always specified over the other choices
There would need to be a valid reason why a designer or architect would chose any of the alternatives, simply because those alternatives are neither beneficial to the building or the builder."Always" might be a bit extreme.. There are certainly alternative build implementations in existence in the UK
You are behind the times.stuffed with wool
You can go Fibolites with 100mm cav and 90mm PIR interlocking (rebated) insulation such as this for example.There seems to be a difference of opinion now.
One builder saying the options are:
- thermalite, 90mm cavity insulation, 10mm gap
- fibrelite, 150mm cavity filled with bats
Another builder saying:
- Thermalite and fibrelite similar u values so go with fibrelite, 90mm cavity insulation and 10mm gap
Are there other options? I just want building control sign off and use as little space up as possible and achieve sound construction and lowest price possible. Prefer to have a gap personally, don't like the sound of solid wall. It rains a lot here in Cheshire. How do you builders do it?
I don't have one. Just want building control sign off.What's your target U value?
We go with the expensive rebated PIR stuff, but it's a faff. It involves a lot of cutting, DPC's at the corners and abutments etc. The alternative is 150mm cav's and Dritherm, but astonishingly, I've yet to build a 150mm wide cav'. All my builds since the June 2022 rules change, have been done with the rebated gear and 100mm cavs.Thanks Nose. So what do you do when constructing single storey extensions?
