I have been inviting gas engineers for quote to replace the boiler and fit couple of radiators in a 2-bed mid terraced house and need help with 2 issues
1- There is already 22 mm pipe suppling the gas to the boiler and the boiler is approx. 10 m away from the gas meter which is outside the house. One gas of the gas engineer quote including replacing the 22mm pipe with 28mm for the gas supply. The reason given is that the boiler is to far from the gas meter and the gas pressure will be reduced from 22mbar to 18mbar by the time it reaches the boiler.
2- All recommended running plastic pipe instead of cooper. I have not worked with plastic pipe.
a. How reliable are they?
b. do they leak?
b. do they leak?
