Planning to replace existing single ceiling pendant light with 9x GU10 bulbs and a 3 gang light switch for 3 separate zones.
This off the top of my head plans involves a lot of daisy chaining so please let me know if it's unsafe, stupid etc.
Remove existing pendant light, original Live, Earth & Neutral is then terminated into an inline junction box.
Replace 1gang switch with 3gang switch. Oringal Live to COM can be put in a splitter (4 way wago?) which will lead to COM1,2&3.
Switch 1 L1 leads to a 3 way wago connector into Position1 of the wago. Live copper wire from GU10 socket terminates at Pos2 in wago. A separate Live wire secures into Pos3 which leads to another wago at Pos1 - the 2nd wago connects the 2nd spotlight.
Process repeats for 2nd & 3rd spotlight. 1 Live row complete, repeat for 2 more rows on Light Switch 2 and 3.
From the inline junction box, Earth & Neutral go into separate 3 way wago connectors basically the same process as the Live wire daisy chain but for all 9 spotlights.
This is for a ground floor dining room. I will not be able to access the ceiling from the floor above but from seeing a few YT videos it looks "doable" to install spotlights with little to no above floor access.
The GU10 socket I'm looking at takes 220-240V as input so need for transformers right?
I'm sure I've overlooked something or probably caused a fire risk somewhere, so many daisychains surely cannot be correct - please let me know - thanks!
