Converting a single skin outbuilding with no dpc
10 Jan 2025
Hi everyone!
I'm looking for some advice on converting my brick outbuilding to the rear of my house into a small home office. I am just trying to guage and plan out what exactly I will need to do it this (and how much I can do myself) to achieve this and would really appreciate some guidance.
The main concern I have is that I don't believe it has a dpc, and even if there is there's a pavement right up against the wall, and the inside looks quite damp. It's also single skin and definitely needs re-pointing (some areas I can see right through). I'd really like some advice here to understand is what's the best / most practical solution here for ensuring I don't get rising damp issues.
I've seen suggestions of tanking (or liquid DPM - which I assume is the same?), alongside PIR insulation board on the floor and the walls alongside some vents?
Someone also reccomended cutting the paving away from the building, but my concern is I can't do that around the back as we have an oil tank there - would doing this be crucial or do I not need to if I have tanked the floor and up the walls?
I'm also unsure if I need any signoff from building regs - as ideally this will be done properly to ensure it adds some value to the property.
I have attached and annoted some images of the outbuilding here:
It's possible, but I'd worry that by the time you've added adequate damp-proofing, insulation and interior surface to the walls, ceiling and floor then you could be left with something like a phone box.
You'd need to treat the wall adjoining the neighbour as an outside wall too.
It all looks very damp. The paving at the side looks like it's higher than the floor, which effectively means it's kind of a basement so will be difficult to damp-proof.
Do you have spare space in the garden? Keeping it as a shed and starting from scratch with a new garden building may make more sense as a home office.
Yeah I was worried about that - I think hence why someone mentioned PIR instead of creating a cavity? I'm also so unaware of how cold it could be, like I wouldn't mind needing to heat it a lot but I'm also unsure if it would be unbearable in winter...
But yes it's all very damp - would tanking not be very useful here?
I do have space in the garden, but we just thought this would be a perfect cosy office space really - only really needing space for an average desk, and perhaps a side chair but maybe I am just too hopeful regarding space
Is the roofspace insulated? This at least costs almost nothing and is worth doing even for a workshop space if it's heated to some level
Yes, it is - I can't remember exactly what insulation is up there, but I have been meaning to go and move it a bit as I can see it from the outside so there's obviously not any room that been left for ventilation
As it's below paving level, which I guess you can't change as it looks like the path adjoins your neighbours, and the lack of a DPC, you'd need to treat it like it's a basement conversion to have any chance of keeping it dry.
You'll be left with approximately nothing by the time you've added that lot. And probably spent as much as building a standalone garden room that could be much bigger.
Are you absolutely sure there's no dpc? The lowest two courses of brick look a slightly different colour to the rest, so there might be something already there.
If not, I wouldn't say it was the end of the world.
You could lay a poly dpm over the floor and lapped up the wall, float some insulation and a floor on top of that.
More polythene up the walls and batten over, insulated plasterboard over that and you'll have something usable. You will have to trial and error a happy medium regarding the heating and ventilation.
You could also, as an option, grind a channel out of the pathway and fit an ACO style channel drain against the wall.
As Ivor says, you won't have a lot of space, but an office could just be a laptop on a desk. Or it could also mean filing cabinets, bookshelves, printer/copier, reference manuals, stationery and water cooler!
I could adjust the paving slightly - perhaps adding a drain along the side of it, but it wont be able to go around the back unless I moved the oil tank away from the wall (this is on a stone slab up against the back wall)
I'm fairly confident but I don't know for sure - how does the colour indicate there could be?
Perhaps I need to look into how much I will actually be left with, as I will still be happy with a small room just for a desk, but if it's something where I'm squeezing in every time, and it's just not useable then yes I'm probably better looking at a standalone garden room.
Having another quick look I do believe there is a DPM under the concrete within the outbuilding, but I can't see any visible DPC.
So I assume I can float insulation and floor straight onto this? But as the outside level would be higher than where the insulation/floor start maybe I tank the floor and first couple of courses up the walls to be safe and then polythene and batten over that, and finally PIR on top?
I'm thinking something similar to this?
Perhaps I also want to do this and wait to see how it goes, and depending on that I may need to grind out a channel as much as possible around the perimiter and install a drain.
In case others have missed it, you can click on the first photo then scroll down to see lots more photos of the interior.
It looks as damp as any underground victorian cellar I've ever seen. I doubt there's a DPC. Polythene membranes probably didn't exist when your house was built, a DPC would be slate or black bitumen in the wall and would definitely be visible. A solid house floor was usually damproofed by coating the concrete with bitumen then lino tiles. The concrete itself is as damp as the soil beneath.
If you're going to seal it all up then you need to allow the water to flow down the inside of the old walls, collect it up and get rid of it. As shown in the cross section diagram I posted.
If the youtuber's conversion remained dry then they're lucky. You may get away with it if there's a low amount of moisture but it's a gamble.
Yeah my house has a slate DPC, but I think this building must have been originally used as a storage shed, or toilet (although we have another extremely small outhouse with a blocked up toilet so perhaps not..) so single skin, no dpc would have sufficed!
Thanks for the information! - Do you know of any youtube videos or articles I can read on up on this method you posted above? I'd like to see the steps involved in it
Looking closely at some of the pictures to my (less experienced) eye it looks like at least some of the water may be coming through the wall under the window as you can see cracks in the mortar inside and out.
Looking closely at some of the pictures to my (less experiences) eye it looks like at least some of the water may be coming through the wall under the window as you can see cracks in the mortar inside and out.
Yeah there's parts under the window I can see right through - it really needs repointing as the first step (maybe replacing some of the blown bricks). It frustrates me that the previous owners also bodged this with what looks like cement...
