Intergas combi no heating. (1)
Can't hurt but unlikely, in unless it was operated in error when topping the boiler up from 1.5 to 1.8!
But OP says not touched and it does appear to be open!
The only valves I've opened are black ones and they are the loop that allows you to increase the pressure, I did try to turn the blue valve on the for right as suggested but it won't budge and I've not touched it .
Heating is constantly on as per previous photo. Is the flow pipe hot? (First pipe on the left).
Brian ,is it so that the boiler was not working for heating before you topped up pressure ?
The mains water outage wouldn't stop the boiler from providing heating . The boilers isolation valves can't turn themselves off ,if you didn't touch them forget them they are not your issue
The boiler was working fine before the water outage and the only reason I topped the pressure up was because after it became apparent that the heating wasn't working I checked for air in the system, there was a bit say a hiss for 2 seconds and because it says in the operating instructions pressure should be between 1and2 bar it topped it up from 1.5 to 1.8 .
No mate the only pipe that gets hot is the one on the right and that only does when you turn the hot tap on.
Sounds like the pump could be stuck, which will need an engineer. You could try super fire, press and hold the spanner button and the plus button twice, should get a capital H, see what happens and report back
From what I was told when we had this boiler fitted was that it's a fully pumped system and considering I don't have an issue with the domestic hot water hotness or pressure wise I would say that the pump is working as it should but like I said I'm not a heating engineer.
I can't see the water outage being anything other than a coincidence.
Was there also a power cut?
As it just so happens there was 2 days before during the storm but it only was off line for 6 minutes.
If it’s the same as the eco rf, then the pump isn’t used for dhw. Fully pumped is just terminology.
