Cable sizing issue - extractor fan powered from cooker switch
12 Nov 2024
My kitchen extractor fan is currently wired as below. Just checking it’s ok. Distance from cooker switch to fcu is very short (about 150mm). Fcu is 3amp.
I assumed the change in cable size should happen after the fcu. It would be tricky to change as no way 2 lots of 6mm are fitting into the switch terminals and not sure I’d get it all in the box even if I find a different switch. Could probably manage 2.5mm.
Spurring from the socket circuit would also be tricky now although perhaps just about doable.
A quick search shows either different opinion on the matter or results that don’t quite match my situation.
Appreciate any thoughts.
