- Joined
- 27 Jan 2008
- Messages
- 29,449
- Reaction score
- 3,618
- Location
- Country
I am used to the loop impedance tester showing ohms and amps, the loop impedance and the PSCC, but my cheap tester shows ohms and volts.
and
not sure what the volts relate to? I looked at this
at £60 and the one shown at £75 and thought worth the extra £15, and the RCD test is A1, even if the loop test seems a decimal point less than most testers, but that must be better to a tester which passes at 1.7 Ω or was it 1.9 Ω clearly designed for radials only.
However, what are the volts for? The instructions have some odd English, I assume "Jump-off time" is RCD tripping time, so "Contact voltage measurement" it seems to call it.
What is Uc am I being thick?
and
not sure what the volts relate to? I looked at this However, what are the volts for? The instructions have some odd English, I assume "Jump-off time" is RCD tripping time, so "Contact voltage measurement" it seems to call it.
