I'm looking to add a 7"x3" timber to support the end of a bit of 18mm plywood which is only supported on 3 sides not 4. Access will be underneath from the garage below. I don't want to take up the floor above only bare minimum floor. So the joist hanger can't 'fold' over the attaching joists (as I would have to take up more floorboard) so can only fix to the face of the 2 joists. Can I use this 'Type 240 Multi Truss Hanger 47mm' (https://www.selcobw.com/type-240-multi-truss-hanger-47mm) to screw directly to the joist? It says I need 'M12 fixing' I assume this means a M12 hex screw (e.g. coach screw) so I need 4 x M12 fixings and a lot of 3mm twist nails per hanger? Is that right?
