D
Deleted member 142255
Noooooooo!
That's still running in the field.
Noooooooo!
I've got serious food envy!!!!!
I just wiped its bum and pulled the horns.Noooooooo!
Roast beef tonight. Cooked just right.
None by the looks of it .What temperature do you use?
I always aim for that. I saw a chef on TV once (pretty sure it was Jean-Christophe Novelli ) show how he does it and it’s pretty foolproof. Get the meat to room temperature first. Seal the edges, cook at 160° fan oven, measure the inner temp and stop anywhere between 40°-45°. Cover with foil and rest for at least an hour before carving. I think that piece took 25-30 minutes to cook.I've got serious food envy!!!!!
Thanks for that. I can still overcook a steak without trying and a beef joint ends up grey almost throughout, then it's tough and chewy. I like it pink and juicy like what you've done.[
I always aim for that. I saw a chef on TV once (pretty sure it was Jean-Christophe Novelli ) show how he does it and it’s pretty foolproof. Get the meat to room temperature first. Seal the edges, cook at 160° fan oven, measure the inner temp and stop anywhere between 40°-45°. Cover with foil and rest for at least an hour.
It looks amazing. Is that topside. Is it well hung. I've never had much luck with topside that rare. I love rare beef but I've only ever been successful with a rib. It's a long time since I've done that, though.
I'm well hung according to the wife.It looks amazing. Is that topside. Is it well hung. I've never had much luck with topside that rare. I love rare beef but I've only ever been successful with a rib. It's a long time since I've done that, though.
This:
That’s what I always get. All the same weight but I choose the cuts that are longer rather than shorter if that makes sense
Yeah, we don't have one. I've never used one, so explains a lotYes, that makes sense. It sounds like a meat thermometer is the key, rather than relying on timing. I guess that is where I used to go wrong! Is it cooked uncovered throughout?
You can normally pick them up for free secondhand at the vets.Yeah, we don't have one. I've never used one, so explains a lot![]()
Not at our vets and not after it's been you know whereYou can normally pick them up for free secondhand at the vets.![]()
Oooooh!You can normally pick them up for free secondhand at the vets.![]()
