Micra fuel tank leak
What kind of container?
Does it really matter? I leave my tractor, often with a full tank, with a breather, parked for six months of the year. I left it full last year, I will guarantee it will be still
full, in a few weeks, when I use it for the first time in 2025. Evaporation, only works, until the airspace is filled with the vapour, then it becomes minimal. Leakage out through the breather, to allow more evaporation, will be negligible.
In the open air, in a container - not so much.
A leaky container is open air. It's a bit like saying steam only escapes in open air. It doesn't. Steam would push open the pot lid and escape. Same principle for petrol. Steam has a certain pressure, likewise for petrol fumes. When the container isn't able to withstand that pressure, the gaseous substance escapes.
Well, have it your way then, simply to avoid a 30 pager - despite being wrong.
Can it, or does it, spill when filled or full ?
Yes, it opened very easily. In fact, so easily I realised there might be a problem. I was investigating a large dirt patch on the body paint around the fill door. Further examination revealed some bubbled up rust where the cap seals might contact the fill neck. This may or may not have opened an air leak. If the tank is filled to the cap, it might leak, or might not. But, who fills to the cap to know?
In a study conducted by the University of Michigan, it was found that under typical conditions (around 70°F or 21°C), petrol can evaporate at a rate of about 4 ounces (118 milliliters) per day from an open container. So, a gallon (about 3.8 liters) of petrol could potentially evaporate in about 32 days
That's the much smaller US gallon, in an entirely open container. A larger amount, in a container, with a tiny hole allowing evaporation to leak out, is a completely different proposition....
Harry Broomfield
It did not come over very well but that was my point if it takes 32 days ish for a open container then the tank with such a small leak would take ages
Cheers
Harry Broomfield
Cheers
No problem, I did understand what you were getting at, I was simply explaining the difference, for the academically challenged ;)
Harry Broomfield
Cheers
You missed the point. It did take ages.The micra wouldn't have a big tank to begin with.
