Cutting tile edges off
15 Sep 2021
Hi
I’m just getting to the stage where I’m doing the cut for the top row. I’m using porcelain tiles and I’ve got to cut between 5 and 15mm off the edge for it to fit. Given the size of the cut, my snap cutter won’t work. I’ve got an electric tile cutter and a disc on an angle grinder. What would you use to cut such small amounts off? My electric tile cutter isn’t great at them. I’ve got polishing pads for the angle grinder to take some chips off but the electric cutter leaves a fair few. I’m guessing I should silicone the edge anyway so it would hide them?
Wet tile cutter.
Hire one if you haven't got one. About £45 and job done.
Wet tile cutter.
Thanks. I’ve got one. It’s just not cutting straight for some reason. But I’ve managed to get through it. Can go surprisingly thin on the score and snap cutter too.
