I have a shallow bow window reveal with hard plaster on the sides (old house, solid plaster walls) but because of the projection of the bow, the head of the opening (under the lintel) has a sheet of plasterboard. This has been removed during the replacement of the window and now a new sheet of plasterboard needs to go back up. The old stuff was nailed to 25mm battens which were strapped to the underside of the lintel with twisted wires! But the new window openers would collide with the lining is it was reattached to the battens again. Ideally the board would be snug against the steel. How would I do that?
