Hi there, hope you can help please.
Novice DIYer wanting to fix into brick that recommends shield anchors.
Never used shield anchors before & read they could crack the brick?
Would resin be a potential alternative please? Something like:
- Fischer FIS P Plus Polyester Hybrid Mortar Injection Resin
- Threaded bolts (concrete bolts?)
- Use a resin sleeve if hollow brick
I’ve read that cleaning the hole is fundamental when using resin.
I’ve also read that when using threaded bar (which I can’t), to twist it in so that the thread engages with the resin. Which I guess would also apply to a threaded bolt.
I understand that I can’t “tighten” the bolt in the normal sense, but was hoping this might provide a reliable fixing please?
It won’t be supporting a super heavy load, and it being permanent is fine.
Apologies if a silly question and a big thank you!!
Martin
Martin
