Can I get some advice with this please. It’s connected to an inline fan (no timer) in the attic and I’d rather rewire it here, than climb into the loft.
Let me explain the situation.
I have this fan switch outside the bath.
Here is the wiring:
The cables at the top are coming from the light and the cables at the bottom are going into the fan.
Brown is live, grey is switch live and I guess the black is neutral. I’ve tested L and SL using my two pole tester.
Here’s what is happening:
- when the fan switch is set to off the bath lights (downlights) switch on and off from its light switch. No issues
- when I switch the fan switch on, the lights come on (regardless of light switch position)
- if fan switch is on and I set the light switch to off, the lights get slightly dimmer and the fan is not as loud
- if fan switch is on and I switch the light switch to in, lights are fully operational, as is the fan.
Can you help me solve this puzzle please. Thanks in advance.
Here is the wiring:
