but it's okay if someone talks about cooking their own stuff, right, or do i have to buy my own sarnies to fit in wi' 'normal' folk'?Chill out man don't get stressed it's just a bit of light hearted food talk...who cares
You'll never be normal always oddbut it's okay if someone talks about cooking their own stuff, right, or do i have to buy my own sarnies to fit in wi' 'normal' folk'?
You can talk about cooking your own stuff of course, why would you think otherwise?but it's okay if someone talks about cooking their own stuff, right, or do i have to buy my own sarnies to fit in wi' 'normal' folk'?
oddly enough we are electricians. Try us.Can I ask an electrical question in here please?
Fire the cannon.Can I ask an electrical question in here please?
God I hope it is something simple,Fire the cannon.
Thought as mich, appreciatedoddly enough we are electricians. Try us.
Yeah, you can do that no problem at all.There’s a double socket next to where I’ll build the frame, so can I take a feed for a spur to feed the macerator and to run the fan
You can supply it from anywhere you want.or does the fan go on the lighting circuit
Personaly I prefer the fan to be taken off the lighting circuit but if it is easier for you to take a fused spur to the fan then that would be ok too. Is the fan the type with an over run timer or is it just an on and off fan?Thought as mich, appreciated
I’m putting an en suite into one of the spare rooms. I need to power a macerator and the fan.
There’s all ready a light there.
There’s a double socket next to where I’ll build the frame, so can I take a feed for a spur to feed the macerator and to run the fan or does the fan go on the lighting circuit ?
Thank you
It will be a having an over run timer.Personaly I prefer the fan to be taken off the lighting circuit but if it is easier for you to take a fused spur to the fan then that would be ok too. Is the fan the type with an over run timer or is it just an on and off fan?
the over run timer in that case needs. the light to supply the fan so that when you switch off the light the fan will keep running and switch on with the switched live of your light.It will be a having an over run timer.
Yes you can do that.It will be a having an over run timer.
Should I feed the light S/L to the fan via the isolator
