Painting / covering kitchen cupboards
30 Sep 2021
I've got some basic white-covered cupboards from B&Q. Some of the covering is starting to split and come off revealing the wood (or whatever it is) underneath. Should I peel all the white covering off, and paint over the wood? Or is a sticky-back plastic a better option?
Thank you
Thank you
Change doors , are you using a toaster or kettle below upper cupboards ?, heat and steam can cause damage .
I am! That explains it. Thanks. Buying new doors isn't really an option unfortunately but I can move the toaster & kettle.
Does this mean I can neither paint nor re-cover the existing doors?
You can probably glue it back on. If you can get some contact adhesive in the split, use the tip of a knife if it's very small. Then hold it down with masking tape til it's set.
I hadn't thought about just getting doors. In an ideal world I'd replace the whole lot but I don't have a job and need to eat first and foremost! These photos show the damage. If I can glue it, that'll be easier but I did like the idea of at least changing the colour.
I had similar in a utility room on one door. I've stripped and painted the whole lot. In a nutshell:
1. Remove wrap, using a heat gun if necessary
2. if surface looks fine, prime, I used Zinsser 123
3. Move on to painting, my paint system wad a undercoat and three top coats.
We're happy with the results, however:
1. It looks more rustic than vinyl wrap
2. It's probably not as hard wearing
3. If your mfd door isn't properly smooth it'll show) some I wish I'd put some fine surface filler on between priming and painting
4. You'd need go do the whole kitchen, and trims/pelmits, or it would show up.
Total cost will be far less than a whole set of new doors. But, outlay forjust one door will probably be more costly than replacing just that door.
