- Joined
- 27 Jan 2008
- Messages
- 27,680
- Reaction score
- 3,352
- Location
- Country
The tank thermostat would trip the over temperature trip if set higher, so have renewed it, there was what looked like sealing compound on the new one fixing setting to around 60ºC it only goes to 70ºC, but I left it as it came. Water now only just warm enough, and clearly not enough to fill a bath, but don't really need that much hot water, but seems no where near 60ºC at the taps, so am I doing something wrong?It has not been in a week yet, so the report as to how much energy used, is not that accurate, but it shows 4.38 kWh used over last week, and before the change was showing around 2.50 kWh per week, so it does seem it is using more, and it said "Tank Full" so the thermostat has clearly turned off. But when switched on, it tends to used a lot less than the 3 kW the element could used, typical around 350 watt, as by time the solar can give 3 kW the tank is already hot.
Winter the DHW is stinking hot, when the oil heater is running, in fact too hot, but there is no valve to turn it down or off. Running C Plan, but I read about stratified water in the tank, and wonder if the low watts is causing less water movement, so is it the iboost+ which is causing a problem? Maybe some one can explain what is going on, and why DHW so cool?
May seem strange, but the DHW has got warmer since writing this. Clearly some thing to do with the thermals inside the tank, but would love to know more about what is going on.
Now shows 4.48 kWh for last 7 days, so it seems power use is going up slightly.
