- Joined
- 17 Oct 2019
- Messages
- 21
- Reaction score
- 0
- Country
This is the situation. We live in an area where due to our rural overhead power supply, power 'outages' are not uncommon (15 days during Storm Arwen a few years ago). My partner has some expensive medications for her rheumatoid arthritis that need to be stored at fridge temperature or they are spoiled.
Until recently, when we were aware of a power cut, we ran the fridge off a Champion 3600w dual fuel inverter generator, located in an outbuilding (well ventilated). We've had to use this three times so far over the past 18 months, fortunately for only between 12 hours and 21 hours.
The fridge's energy consumption is 58 KwH per annum, so it's quite efficient. However, because of the nature of the generator's power supply, it has to be run constantly to power the fridge with the usual noise and costs (propane and engine oil).
A few weeks ago, I purchased an Ecoflow Delta 2 Max 'power station' rated at output 2400W and battery capacity 2048 Wh.
This seems to work a treat. It's quiet and when just powering the fridge the estimated run time on the read out is something like 66 hours (even taking into consideration the 'idle consumption' of the AC inverter).
Given that spare capacity, it would be useful to also run the freezer at the same time. But (and thanks for bearing with me), while the fridge is in the kitchen, the freezer is in the adjoining internal garage, the other side of a fire door. I could run an extension cable from the Delta 2 max through the door to the garage by leaving the door ajar. Ok in the summer, but less so in the winter.
What would be the best way to run an extension from the Delta 2 max, through the wall, to the garage?
I could use a system like we have at present with the genny, through the wall between the house and adjoining outbuilding, but that has a 16A commando connection, and I'd want to avoid something so bulky in the kitchen. Any ideas?
The mains AC power input to the battery ('power station') for charging it, has a 240, 3 pin standard ac wall plug which attaches to the battery with a kettle-like connector (an IEC cable?). Is there something like this on the market that I could use from the output from the Ecoflow battery, to a flush socket in the wall on the kitchen side, and then through to a socket on the garage side, from which I could then run power to the freezer?
I can't see anything online like this.
Or maybe there's a better method?
Thanks in advance.
Thanks in advance.
