He just spurred a new socket, maybe he wasn't registered just done a few tests and left probably happens all the timeMmm, that fills me with no confidence at all! Are you sure he was qualified, did he give you anything in writing?
Yes, I think he was qualified. I got him from a website that checks builders’ qualifications, and he put a sticker on my installation after checking it.Mmm, that fills me with no confidence at all! Are you sure he was qualified, did he give you anything in writing?
Oh dear. To be qualifying be on most of those “sites”, all you need to do is pay some money. And maybe get a “review” from your mother in law.Yes, I think he was qualified. I got him from a website that checks builders’ qualifications,
For the record, this is the website of the electrician I used:Oh dear. To be qualifying be on most of those “sites”, all you need to do is pay some money. And maybe get a “review” from your mother in law.
kb-electricalservices.co.uk
It's the usual time saving method that conservatory installers/builders do as most homes have a ring circuit for sockets and it's easier to install a FCU(s) rather than extend the ring or add in a new circuit.There was no absolute reason that it needed to be fed from an FCU, for a simple spur from the ring, assuming a spur from the ring, which further suggest if there was no fuse, it was faulty workmanship or materials.
I’m a bit lost in the technical details here. As for contacting the original electrician back… yes, I could do that, but I don’t think it’s the best option. He fitted the socket about seven years ago and it has worked all this time, so he is going to say it is no longer under guarantee. Plus, if he didn’t do a very good job the first time and I call him again to repair it, he is quite likely to not do a very good job the second time either. If I am going to have to pay to get the problem fixed, it would be better to call someone else who might do a better job.A bit more convincing, but why not get back in touch with them, explain the socket stopped working, and ask them where it was fed from, and why it might have failed?
One doesn't need to either install an FCU or extend a ring in order to add one socket (single or double) - it can just be installed as an unfused spur from a ring final (or branch from a radial)It's the usual time saving method that conservatory installers/builders do as most homes have a ring circuit for sockets and it's easier to install a FCU(s) rather than extend the ring or add in a new circuit.
I know that.One doesn't need to either install an FCU or extend a ring in order to add one socket (single or double) - it can just be installed as an unfused spur from a ring final (or branch from a radial)
Could be used to isolate the conservatory in an event of a fault.
