2 way switches
16 Jun 2025
I got 2 switches both got 2 switches to run 2 lights the missus took em off to paint now I got 2 new switches i looked atthe swicthes online and can't find what I got
I got one with yellow red blue and one with blue red in one and 2 with blue red yellow 2 with red blue 2 with red black in the other
Old swicths gone in bin had 4 holes each new switches got 3 holes 617pm screwfix
long room one end 2 light work together from both swicthes other end one works from both switches
me cameras shot but allcan take is 23 wires an 7 wires all the bear wires go on the termimal in the back with a green wire to the front
Mmm blue and red in a cable? could that be a 3C&E with the yellow cut off
or my guess is brown and blue
Is this combination what you have?
I make it 20 and 7 including earth wires
Image of 617PM
very standard 2G 2 way switch
Image of 2 gang intermediate switch with 4 holes
Are there any other switches for these lights?
Do you have anything to test with, such as a cheap multimeter like this?
I get meter missis get from screwfix some red wires very dark my eye not so gut i got 3 very dark red and 4 red 2 yellow 5 bleu 2 black 7 bear 7 wires in wall altogeter 23
4 holes?
Neutral parking terminal perhaps?
Can you get them out of the bin?
I get meter missis get from screwfix. some red wires very dark my eye not so gut. i got 3 very dark red and 4 red. 2 yellow, 5 bleu, 2 black, 7 bare. 7 wires cables in wall, altogeter 23 wires.
Excuse me for editing your reply to understand it.
This gives 3 brown, 4 red, 2 yellow, 5 blue, 2 black
My friend, you need an electrician.
I hate to say it but I think that's right
4 holes?
Good call, didn't think about those.
I'm out for the evening, good luck.
Thank for your help.
I explain, You may understand we are not native to your country. Papa is old and disable, his quite good with power but this one lots of wires. Mama and me working. My English is best.
Mama took the switchs off and one broken so she put on bin and gone. We don't have working camara but she draw a map of the wires which I make on computer. I think this ok
Using meter we find this and make new switch
We make this, one light is on and fuse box switch bang when we put it off
Mama and me go to work now, we be home this evening.
I think so too.
But I will say that if that 3 core is connected like that and the light works in one position and the breaker pops in the other, then the blue must be a neutral?
Red: Live feed
Yellow: Switch
Blue: Neutral
Or at least, if that is not the colour convention, one of the yellow or blue must be neutral.
Or there is a dead short somewhere!
I think so too.
Red: Live feed
Yellow: Switch
Blue: Neutral
Working on that and this
4 holes?
Thank you for a lovely sketch and to Mama for making the original.
It looks to me that the upper left of each swicth unit is the 'loop' terminal and there are 2 loop outs cables 6 & 7 to other lights in the house.
From that it appears there are 2 conventional 2 way systems but the right switch plate is incorrect - see purple amendment
As it is now I believe I can identify all neutral wires: All blues and blacks from 3,4,5,6,7 can be terminated in a connector, such as a Wago or a piece of this
Reds from 2,5,7into another connector, after that only a question of identifying which is cable 6 as a loop out and 3,4 as switched lives, presumably to 2 lights
Thanks!
I'd got as far as bunching the feeds in and out, then I had to go away and commence dinner prep.
