- Joined
- 12 Oct 2024
- Messages
- 277
- Reaction score
- 61
- Country
Hello,
Where the roofs of my existing house and extension meet at the GRP valley tray, the tiles on the existing roof seem to kick up a bit at the end so you can see a slight wavey effect when you view it from further back. Not nice and straight.
This seems to boil down to the rafters on the existing house being less thick than those supplied with the truss roof of the extension. Therefore, the roof battens of the extension sit a little higher and so do the tiles. These tiles then do not need to ride up over the ribs on the side of the GRP valley. The tiles on the existing house though, being a bit lower (maybe 10mm) have to ride up over these big ribs causing the slope effect.
The only solutions I can think of are:
- Just leave as is, although it is a bit grating to look at. I've attached photo but not as obvious as in reality.
- Replace the GRP valley tray with one that doesn't have high side ribs. Do these exist?
- Use packers under the battens on the existing roof further along from the valley and try to achieve a more gradual build up so the end tiles at the valley tray do not obviously kick up.
Thoughts?
I suppose we could use less thick ply under the tray to drop it down a bit and make its ribs lower but this could then be a problem for the extension tiles where they meet it? Unless we make it lower only on the existing house side. The ply os about 17mm thick.
Thoughts?
