Well you could just wrap the spigot with hessian tape impregnated with boss white and ram the whole lot into the gap. Not something I would recommend but it's something you could do yourself without having to get the owners 'tradesmen' involved.
Have you tried to clean your hands after pipe wrapping with Denso Tape? If so, you will know what a ******* stuff impregnated tape is. I was forced to use it once, but never again.Well you could just wrap the spigot with hessian tape impregnated with boss white and ram the whole lot into the gap. Not something I would recommend but it's something you could do yourself without having to get the owners 'tradesmen' involved.
You've obviously lived a very sheltered life, or, considerably younger than me.Hemp's for working with boss-white on long-screw gas fittings, no?
Well I certainly wouldn't recommend using Denso tape in that situation.Have you tried to clean your hands after pipe wrapping with Denso Tape? If so, you will know what a ******* stuff impregnated tape is. I was forced to use it once, but never again.
Denso Tape™ - Anti-Corrosion Petrolatum Tape
Denso Tape is a surface tolerant anti-corrosion petrolatum tape for steel pipes, fittings and structural steel.www.denso.net
Do you actualy have an indoor toilet yet?Before flush cones, all we had was red lead and putty to seal the flush pipe to the pan.
