- Joined
- 25 Jun 2025
- Messages
- 4
- Reaction score
- 0
- Country
Hi all, I've read many posts on the subject but thought it was time to post my own query. The ultimate question - will a 50x150 roof joist be sufficient?
Background - I'm building a single leaf (100mm) concrete block garden building with a flat roof design, keeping below the 2.5m rule for permitted developments. The building will be Class 6 under the building regulation exemptions and therefore does not need to comply with building regulations, however I believe the regs are there for a reason and have still reviewed Approved Document A and trying to follow it or follow closely.
There will be no permanent access to the flat roof and we live in the South of the UK, so snow is not a big concern. Biggest live load will likely be the neighbours' cats.
The building is a slightly unusual shape due to the shape of the garden. The front wall (which has 2 doors and a window) is 4.8m long with the end walls square, however the rear is tapered. Essentially the left hand wall (and hence the roof) will be 5.7m long but the right hand wall is only 2.6m long.
Whilst ideally I would choose 75x220 joists, this takes me over the 2.5m.
On top of the concrete blocks will be a wall plate which will be strapped to the walls at 2m centres (at least), firrings about 100mm high at the high end (albeit I could take down to 72mm to meet the 1:80 drop if necessary), topped with 18mm OSB and then EPDM. Cold roof insulation above plasterboard finish.
So my options or any other suggestions from you lovely people:
a. 50x150 joists at 400mm c/c will be fine - stop worrying - plenty of tolerance in the span tables.
b. 50x150 joists - but do 200mm or 300mm centres on the left hand side (hidden by plasterboard and soffits/facias so won't be seen)
c. trust the span tables - go with 75x220 and redesign something else
Thank you in advance for any advice or suggestions.
James
James
