I had a problem with a set of scales, the earth leakage was too high when doing the PAT test, it seems it was fitted with a filter to take the spikes out of the supply, which was causing the leakage, the fix was to remove the filter, it may be something similar, there may be some filter which causes some leakage.
We can have from memory a few mA leakage, seem to remember maximum is 3 mA unless special earthing is done. All items together should not exceed 30% of the RCD rating, so for a 30 mA RCD that's 9 mA, and the RCD should trip between ½ (15 mA) and full (30 mA) but in general it will trip at around 26 mA.
So much depends on how much is already leaking,
here it shows my house is leaking 8 mA, since it feeds 14 RCBO's (RCBO is a MCB and RCD combined) I am well within limits, here
I am doing a ramp test, one could do it with all connected and with nothing connected and the difference would be back-ground leakage. We can also test without items being live, with this tester,
however it uses DC not AC for the test, so it can give a false pass if leakage due to capacitive or inductive linking. However my point is the induction hob could simply be the last straw, but likely it is faulty as 3 mA should not normally tip the ballance.
