Macerator choice and install query
27 Jul 2025
Hi Everyone,
I have read various threads about the use of macerators and was hopeful of some constructive advice, from anyone in the know. I’m not a qualified plumber, but I am a good DIYer and fitted many bathrooms and kitchens, together with lots of other types of work, but I have no experience of macerators. My aged in-laws live in a bungalow and they have got to the point in their lives where they need to have more than one w.c. as they both have frequent visits and they also need to have a walk-in shower due to mobility problems. They have an existing bathroom, with bath, basin and w.c. (which they cannot lose the use of, whilst it is modified) and they have asked for an en-suite to be provided off, their bedroom, which means taking some space from their integral garage.
The building work is pretty straight forward, but there is no suitable drainage point nearby and it is impossible to get to the foul water drainage without the use of a macerator and pump. The en-suite will be fitted with a shower, basin and w.c. They are both aware that the only things that should go down the loo are wee, poo and toilet paper and as it’s an en-suite they are able to ensure that only the pair of them will be using it, so there will be no uncontrolled use by visitors etc.
The new wall that separates the en-suite from the remaining garage, will be where the w.c., basin and shower discharge towards, so the aim is to install a macerator on the garage side of the new wall, (for ease of access and also to endeavour to reduce noise impact in the bedroom and the other adjacent rooms) with the discharge route being vertically up into the roof space and then across to the gable wall, to ultimately discharge into the existing soil pipe, with all joints being solvent joints and any bends being 45 degrees, and there is plenty of room for a non-return valve on the riser, so from a discharge route point of view, things are reasonably straight forward. The maximum lift will be 3.5m and the max distance to the soil pipe (including the lift) will be 13.5m.
I have researched macerators on various forums and spoken to a number of suppliers and manufacturers and I think I’ve narrowed down the macerator choice to one of two, either a Grundfos Sololift2 WC-3 or a Sanipro XR UP, as both of these seem to have good reviews, the capacity required and also, importantly they both seem to allow the macerator to be fitted to the garage side of the wall. Unless I’m mistaken both have in-built vents as options, both also have the option of having an alarm fitted and both have very similar noise levels. There is a price difference between the two, but the cost of the macerator is definitely not the deciding factor.
From what I can gather, the Sanipro has a max incoming water temperature of 35 degrees (which I feel is possibly a tad lower than needed as one of them likes hot showers), and the Grundfos can deal with much higher temperatures at a max 90 degrees which is way above the safe water temperatures that are ever going to be in use, in the en-suite. From what I can see both can be fixed to the floor (concrete therefore hopefully less chance of noise transfer), and the Sanipro can also be fitted to the wall. Just on the noise, I think by placing the macerator in the remains of the garage, will help tremendously on the noise front, particularly if everything is mounted correctly (it’ll be reasonably straightforward to enclose and carryout further sound proofing within the garage, if needed once operational) but I’d be more concerned about noise transfer through the stud/block wall.
Sorry for all the detail, but if anyone has experience of either of the above (or perhaps can offer an alternative), I’d gladly like to hear your views. Also, if anyone has a view about whether an insulated stud wall or thermal block wall would be better, I’d welcome views on that as well.
Saniflow is my go-to macerator because of their service department. That 35c is the temperature at the unit and not that of the discharge from shower tray and into the unit. With it fixed internal to the garage, I doubt if 35c will be reached under normal usage. Shop around if you decide on Saniflo as some suppliers offer good discounts. As you will be buying one for a disabled person's usage, claim back your VAT.
Can you easily get replacement non return valves for the Saniflo?
I'm only asking as my old macerator is nearing the need for replacement and the non return valve is the main thing that has needed replacement over the years.
I have had a Saniflo in for 25 years without problem so I would recommend them. I also installed one in my mothers house in similar circumstances to yours and would definately recommend installing in the garage rather than the en-suite for ease of access and noise levels. While they may be fit to use it properly at the moment things can change quickly with the elderly and easy access is really necassary . Also as far as I recall you had to have a gate valve rather than a non return valve in the waste output. The saniflo model I fitted would work with a 25mm waste so made instalation simple
We have a Sanislim in our downstairs loo. It is supposed to be able to take a wc, a basin and a shower. We've only used it for wc and basin. It just sits on a concrete floor on some rubber pads. Ours is also boxed in so, very quiet. It’s been in for 25 years. It stopped working once and with some help from this forum I fixed it myself with a £5 capacitor.
Many thanks for the responses so far, extremely helpful
Scally-Ho that’s great information, we’re currently looking into the VAT situation thanks and the link you have given is very useful
jj4091 – Its reassuring to hear the longevity of yours, I was hoping for a minimum 10 years, but if we get to 25 years, that would be fantastic and thanks for the tip about gate valve and not non-return valve.
Mottie - I have seen your posts before, even recognise the photo and the 25 year life so far is also very re-assuring. Acoustic/rubber pads apart, could I ask, did you acoustically insulate inside the boxing in or do anything special to acoustically improve things with the discharge pipe at all? Just trying to find out quite how much more acoustic protection I should consider.
Many thanks to all so far
Nothing apart from fit an internal shelf in that box. I’ve left the installation instructions and any spare bits 'n' bobs like clips and connectors in there.
If anyone has time to look at this, I’d be grateful for thoughts.
I think we have decided on the Sanipro XR UP, with this being fitted on the opposite side of the wall to the en-suite in the remains of the garage. This macerator allows a max of 500mm with a min 5% fall between the toilet outlet and macerator and from what I can see, it’s one of the few that do that. It’s also a quieter macerator than most and there are plenty of engineers in our area. This will allow us to place the macerator outside the en-suite - which the in laws prefer so there’s no view of the macerator or boxing in in the en-suite - it also means that we can place an acoustic box around the macerator in the remains of the garage. In an effort to reduce noise further and after discussion with Saniflo, we are thinking of fixing the macerator to the floor, on a 3mm thick rubber mat (solid floor) and placing a box around the macerator, with acoustic tiles on the inside and leaving a min 4cm between the macerator and acoustic tiles and also leaving a 1cm around all the incoming and outgoing pipework and a further 50mm diameter hole in the box - the gaps are to allow air into the box to prevent overheating and allow the macerator to vent.
We’ll be using 32 dia discharge pipework with an access point on it and also a non-return valve/gate valve close to the macerator end of the discharge pipe. If after everything is up and running there proves to be too much noise from the discharge pipe (which I think unlikely), then we can also add acoustic insulation to that pipe as well.
Just wondered if anyone has done anything similar or has got any views about the acoustic box or the extent of the box ventilation etc
I have done similar instalations without the accoustic instalation because frankly they don't run long enough for the noise to be a problem you soon get so used to it and you stop hearing it. Like living next to a train line. In my opinion access is the most important aspect as someone will definately put something down or something will unknowingly go down the loo that should not. Toilet cleaners that hang on the rim of the bowl can be a particular problem.
Don forget that the unit will be running while the shower is discharging and study the installation guide as to cooling arrangements.
That depends on age and for what model. I have some in stock
The non-return valve cannot be replaced with a gate valve, are you are talking about the cubic where fitting one to the discharge line is required for service or repair work.
Not sure what the model was but the instalation instructions just called for a gate valve at the macerator discharge in order to be able to isolate the waste pipe for maintenance purpases. As far as I remember there was no mention of a NRV. It was a few years ago so perhaps the advice has changed. I haven't done one recently so perhaps it was the Cubic model if that is what you meant.
