How to seal a crack in a metal milk churn?
11 Sep 2007
I have an old, small metal milk churn (must be about 16" high, about 10" diameter at its widest point). It's filled with water and the dog drinks from it.
However, the churn has sprung a leak - there's a small crack that's about half an inch long - the leak has been intermittent because there's a fine layer of algae on the inside and sometimes that stops up the crack for a while.
I guess the churn is aluminium as it's not magnetic, that said the handle looks like steel but that also isn't magnetic .......
I've thought of using a suitable glue or silicone on the inside but it would need to be non-toxic.
Another alternative would be to line it with plastic, but that has its own problems.
Any other ideas please? I'm trying to avoid buying a new container.
A large patch of Gorilla tape on the inside and outside should do it.
I doubt it would be toxic and cause a dog any harm, but you might like to check. Personally I can't see any risk.
Thanks, a nice idea but just checked and it's not food safe.
I'm now thinking of food grade silicone sealant, but it seems a bit expensive to buy a tube of it costing about 9 quid when I only need a very tiny amount.
Was going to suggest "JB Weld",
But better yet is "JB WaterWeld" - which I did not know existed until just now.
Quote: JB WaterWeld epoxy putty is safe for use in contact with potable (drinking) water after it has fully cured. It is specifically designed for sealing and repairing items that come into contact with water, including pipes, tubs, showers, drains, and even portable water tanks.
SFK
SFK
Thanks, I've decided to go for this - JB Weld JB8277 Waterweld
As you state, it's safe for use with potable water, so my dogs will be happy to be able to drink out of their favourite container again. :)
Thanks to everyone else for their suggestions as well.
