Don't really know what you're apologising for? This is just a light-hearted thread, back in 1980 I worked for a Dutch company in Algeria, and I can't remember what sockets were in our cabins, you could work out if the camp electrician was Dutch or English, voltage 240 if English 220 if Dutch.
I know we had a problem with in cup boilers, they had caused a few fires, and had been banned, but that did not stop people using them.
I think power is moved to Europe or to UK as DC, but not sure on that?
In the UK, panels made in Europe have presented a problem, where often the Schuko socket was put inside the panel to power laptops when monitoring the PLC. There has been many of a debate as to if allowed, as they are inside a panel, so not for anyone to use, and in the main laptops are class II, and often not enough room to change them to BS1363.
At one time you could get BS1363 plugs with the lead so if pulled it would simply unplug, but
for some reason most plugs have the lead out of the bottom, so pulling the lead, as when one trips over the lead, causes the plug to be damaged, and causes a health and safety issue causing a fall, rather than simply unplugging. And I have seen many times a plug work its way out of the socket, so it does not stop that happening.
Even the version for the disabled
has the cable out of the bottom. This
seems to be the way around the problem, and odd there is no rule to say can't be used, and it does allow line and neutral reversal.
