Disconnected cable inside garage fuse box
1 Feb 2007
Argyll
Hi guys, I have a garage fuse box installed a few years back by a qualified electrician with a 3 core cable from the house consumer unit. All has been ok and working as it should until today when I was moving some boxes and inadvertently pulled the 3 core.
The 3 core cable has brown, grey and black. The grey cable came loose and although power registered on every external cable as live (on my wee power pen) none of the lights or ring sockets worked.
At no time did the fuses trip in the garage, nor did the fuse in the house unit.
I isolated the power from the house and opened the garage fuse box as shown, the grey cable having exited the fusebox as I was doing this.
I have the brown cable going to the top of the left MCB, and the black cable (which has been sleeved with earth sleeve) going to the eartn bar at the top right of the photo.
My now loose grey cable needs connected, but I don't know to where.
Would greatly appreciate your advice, and apologies for any non standard electrical descriptions above.
The grey wire is most likely the neutral, it should have been marked with blue tape or sleeving, but that may have fallen off, or many never have been fitted in the first place.
The live and neutral should go to the terminals at the top of the RCD (not MCB) on the left.
But what concerns me more is that brown/black/grey usually indicates an armoured cable, armoured cables are usually terminated with a gland that restrains the cable and earths the armour. It sounds like this installation may have been a lash-up from the start and is in need of some remedial work beyond reconnecting the grey wire.
I am also failing to see any sign of a live, entering the top of the RCD.
Well it certainly is a bit of a dogs breakfast.
I suggest you ask a pro to investigate and take remedial action.
It is difficult to see exactly what goes where (or what is intended to go where) fromyour pictures.
Also the fact that pulling on the cable while moving stuff suggests that the cable needs to be fixed to the wall.
