- Joined
- 19 Jan 2024
- Messages
- 48
- Reaction score
- 6
- Country
It was all going so well!
I've removed the old plaster in my hallway back to the brick in places, and filled all round the edges with foam, mortared the old brickwork and I was just trimming the excess foam off and bzzzzzzt, right up my arm. I feel OK, index finger is a bit hot, and no sign of anything else going on, but that was close!
Whoever wired this up (Wasn't me), has wedged the cable between the front door frame and the plaster/brickwork so only the very edge is visible. There's some kind of thick rubberised (might be tar) sheet and I thought this cable was that, and just trimmed it, as I have done a few times this week .I'm going to need to fix this length of cable before my plasterboard goes on. Should be OK with a simple low profile junction box and remove the damage and joint back together? Any recommendations for a flat as possible junction box, or other ways to rejoin the cable safely, long term, that are low profile, as in under 20mm if possible?
