Open cavity after removing window sill
11 Sep 2023
Interior window sill was removed recently and now I'm left with an open cavity underneath the window frame.
The cavity is filled with blown in mineral wool insulation, but there's a small gap just below where the sill would normally sit.
Should I top up that gap with loose insulation refill? Does it have to be mineral wool, or is another material acceptable?
Do I need to fully close off the cavity before fitting the new window sill? Since the window was newly fitted, I cannot use a cavity closer. What's the proper way to close it up?
I'd appreciate any advice on best practices here.
Thanks!
You could use Celotex insulation board , or rock wool, or expanding foam ( protect frames if you foam as it can mark them ).
Thanks!
As said above…
