Hi. I've recently noticed the hot water flow/pressure in all taps is pretty low, when shower is on and a hot water tap opened the shower flow almost stops. Cold water pressure appears ok. I have a Ideal logic combi 24 boiler that has given no issues and is regularly serviced. Central heating is fine and hot water gets hot no issues but flow poor. I've bled out all the radiators and set the boiler pressure to 1.5bar but still nothing. Is there anything else easy to try or should I just call out my regular heating engineer next week. There are no obvious leaks I can see and boiler pressure doesn't drop. What should the flow be in hot and cold and is there an easy way to test??
