Hi all,
First time poster! I've recently moved into an older property and dealing with a few gremlins. First issue I came across was damp in one of the living rooms which ive hopefully now resolved be opening up an old blocked fireplace and taking all the old fireplace out. Now I've tackled the internal issue (hopefully!) I'm looking to deal with external damp.
As you can see from the pictures about 3 courses up from the DPC there's a band of horizontal damp. I'm not entirely sure what the issue could be, using a moisture meter the bottom courses of brick are dryer that the ones higher up. Could it be historical damage to the bricks that has turned them porous and it's just a case of sealing them or is there anything else I should be investigating. There was a ton of salt on the bricks which I've cleaned off as I assume that will have been drawing moisture in. Where im pointing on the pics is where the DPC is. I'd also like to repoint the wall but unsure what the best mortar mix would be? Thanks Matt
