- Joined
- 30 Sep 2025
- Messages
- 2
- Reaction score
- 0
- Country
I recently moved into a house that has a Valiant ecotec plus 415 boiler, gravity fed with an hot water tank. To get the boiler to heat the hot water I have to manually set the heating flow temperature (which is the central heating setting) on the boiler itself. The controller we have downstairs by the thermostat does seem to do anything. The DHW temp is set at 50deg
If i turn the heating flow temperature to 0 then it turns off the central heating and doesn't heat the water. The heating controller has options for heating and hot water but none of the functions seem to do anything on the boiler. It was recently serviced (before I moved in) and it came up with a clean bill of health. Any suggestions on what to do next?
