Boxing in - wiring and heating
15 Feb 2008
I’m renovating an old bungalow; fitting new rads and new/additional mains sockets to rooms.
Is it okay from regs / good practice point of view; to box in 15mm copper heating pipes and my wiring (for new sockets) in same box.
I’d planning to add the (dry lining type) socket into the same box - I’m trying to avoid lots of chasing out cable runs.
Thanks D
Thanks reply.
So if ran a section of conduit inside the box and routed it as far from pipes as box would allow; would that suffice for separation.
D:-)
Be aware that putting the cable in conduit may alter its current carrying capacity; size it and/or the breaker accordingly
I think I understand (cable heat dissipation ?); is that a more theoretical consideration. Is 2.5mm^2 cable in a 25mm conduit any worse than under a galvanised channel buried in a wall chase ?
Thanks D
Thanks D
It’s a different installation method. Easier to insulate the pipes.
Yes. It doesn't have the wall on one side.
Thanks - that never occurred to me; so it uses the wall as a heat sink.
I’ll insulate the pipes as suggested and bin the conduit idea. I might partition the boxing - aiming to keep the pipes and insulation one side / wires the other.
Thanks D
Just looking at an older post where someone was asking advice for boxing in pipes in garage and the advice suggested a double skin box (because of Reg’s or control) - is this only because it’s a garage.
D
