Rotating a stop cock
6 Apr 2010
Hampshire
Morning all
I need to rotate this stop tap so that the handle is facing upwards. This is to allow space for an insinkerator.
Ill obviously isolate the water before I do anything, but can I just loosen the bolts on either side of the stopcock, and then rotate it around and then retighten?
Morning all
I am not a plumber... but if you are talking about an isolating valve... I see no problem with loosening the two nuts to orientate the valve and then tighten it back up.
As @accelerator said. It would help proper plumbers to reply if you post an image.
